Here is the problem. I don’t want to buy Capra axles and have the same problem with my G shot. I bought a front AR45 and two rear AR45 portal because I was thinking about a portal rear with straight front. But the gearing issue made my head hurt. I have been scouring the web and am just more confused.
Axle diff gears 8/30 = 3.75:1
Ring and pinion O.D. 8/27 = 3.38:1
Portal gears 12/23 = 1.92:1
TGH O.D. portal gears 15/20 = 1.33:1
Hot Racing O.D. Portal gears 13/22 = 1.69:1
Total axle ratio 7.2:1
TGH Portal overdriven axle ratio 5:1
H.R. Portal overdriven axle ratio 6.35:1
Ring and pinion overdriven axle ratio 6.48:1
Both (TGH) overdriven axle ratio 4.49:1
Both (H.R.) overdriven axle ratio 5.71:1
TGH portal OD percentage 36%
HR portal OD percentage 13%
Ring and pinion OD percentage 10.5%
Both (TGH) OD percentage 46%
Both (HR) OD percentage 23%
TGH OD front, ring and pinion OD rear total OD percentage 26%
HR OD front, ring and pinion OD rear total OD percentage 2%
TGH OD front HR OD rear total OD percentage 24%
Internal transmission gears 30/54 = 1.8:1
Ratio before pinion selection 12.96:1
Spur 34t pinion 17t = 2:1 total= 25.92:1
34/16= 2.13;1 = 27.6:1
34/15= 2.27 = 29.42:1
34/14 = 2.43:1 = 31.49:1
34/13= 2.62:1 = 33.96:1
34/12= 2.83:1 = 36.59:1
34/11 = 3.09:1 = 40.05:1
34/10 = 3.4:1 = 44.06:1
34/9= 3.78:1 = 48.99:1
Final drive ratios are based on stock axle gearing
I don’t want to buy another set of portals.
I see the other rigs like the Capra and they are not super slow with portals. But a lot of portals vehicles have two speed transmissions.
It cost 80 buck for enough gears to change the portal ratio. A small spur and big pinion cost 20 but it might be jumpy or drive poorly on the rocks.
