- In my recliner
- Flying
There's hope for me yet!
I just don't see that happening any time soon.
One of these days maybe I will have your respect my friend.
I just don't see that happening anytime soon.![]()
.Oh, okay then. Just don't look so sad..
Since you're being honest with us, we're willing to let you slide for a while. Any other major delays and you'll be added to the "FastEddy Chris Craft" file.:LoL:
I for one, really felt for what you were going through. It's pretty scary when a little one gets that sick. We're ALL really glad to hear that everything went well and he's up and running again.:celebrate3:
On the diffs, Compress the spring with a pair of pliers a few times before you install them. Tighten them up all the way when you build them and back the screw off 1/8th on the front and 1/4th on the rear. Check them again after 3-4 packs of running.
Its best to sand the edge off and seal them with CA.
Cit a strip of 300 grit or finer sand paper the width of the slot. Slide the paper through and so a "Shoe Shine. Not that much just enough to slightly round them so they dont cut the Batteries. Use a small brush and seal the sanded edges with CA to seal them off if you want to. If you dont have sand paper go steal an emery board from your wife.
If you are using anything greater in size then a 3600 battery you DO NOT want to use additional wrap on the bats. The newer larger cells are a tad bit larger then the older ones and wont fit if you wrap them.
