I have 8s spektrum 8 I'm running with itFor speed runs a 1250kv motor
For speed runs a 1250kv motor isnt the way to go unless you can run pinions the size of spur gears. Personally Id look at a Castle 2200kv on 6S for speed runs. As for gearing your gonna want to get as close to 1:1 gear ratio as possible or even less than 1:1 if you can and have the torque to spin it. Thats the only place where your 8S 1250kv is going to be faster than the 2200 on 6S but I'm pretty sure you wont be able to get less than a 1:1 ratio.
The ESC has nothing to do with RPM, only amp draw. The ESC will only hand out what the motor asks for amp wise, even if it's more than the ESC is rated for and fries the ESC.id try to achive the max rpms the esc can handle..I'm pushing a few of my http://poseidonrc.com/index.html a few thousands past there rated max rpm .I'm only running 4 cells .
My 8S 1250kv spectrum system with a 34tooth pinion is way faster than that 2200kv castle on 6s. Not even close! With it at 70% so you saying you need something bigger than a 34 is incorrect. I could actually run a 28-30tooth and smoke that castle systemthe issue isnt with the ESC. The issue is that a 1250kv motor on 8s is only capable of about 37,000rpm. The 2200kv on 6s is capable of almost 49,000rpm. So unless you can run something a lot bigger than a 34T mod1 pinion gear the 2200kv from Castle Creations is going to be faster than the 1250kv. You can use that ESC with the 2200kv motor though
My point was that unless you can overcome the RPM difference with gearing, then the 6S is going to be faster. a Castle 1515 can spin a 34T spur on a Felony for speed runs so unless you can get a bigger spur than that on the Spektrum 1250kv then the 1515 is going to be faster. Its a rather simple concept.My 8S 1250kv spectrum system with a 34tooth pinion is way faster than that 2200kv castle on 6s. Not even close! With it at 70% so you saying you need something bigger than a 34 is incorrect. I could actually run a 28-30tooth and smoke that castle system
Yes, but no one talks about that because as long as you are running within the specified voltage ranges you aren't hitting that hardware limitation, so it's a moot point. That's why manufacturers don't list it as a spec, or at least not most of the main brands anyway. Just because an ESC has limits doesn't mean it has anything to do with dictating what RPMs the motor run at.ESC's do have limits. They can only turn on and off the coils so fast.
Simple google search
.This point wasn't even central to the OPs topic, so I can only surmise you're trying to pick yet another fight with me 2.5 years after this post was even posted.![]()
Man google must be a hidden thing these days. Esc’s with rpm limits , interesting lol.
Which was clearly to contradict:Once again the ESC has NOTHING to do with RPMs. Only 2 things that affect RPMs is how big of a lipo you're using and the kv rating of the motor
esc has a major amount on rpms . if esc has a 50k limit you aint going past that
What does this have to do with my comment? I never commented or disagreed with that.Yes, but no one talks about that because as long as you are running within the specified voltage ranges you aren't hitting that hardware limitation, so it's a moot point. That's why manufacturers don't list it as a spec, or at least not most of the main brands anyway. Just because an ESC has limits doesn't mean it has anything to do with dictating what RPMs the motor run at.
You're the one that needs to get over me. All you're doing is following me around the forum trying to argue with me. You're pathetic.Get over yourself! My reply was to this comment:
But since you brought it up do you still stand by this comment without trying to justify it's a moot point?
Only commented that there is a max RPM limit an ESC can support. I dealt with Sevcon and Curtis controllers.
