What would happen??
AC48
New Hampshire
I am new to r/c and I was wondering what the importance of a flywheel is other than to hold the clutch. What would happen if you tried to run an engine with no flywheel??
It serves two purposes.
1. To moderate speed fluctuations. Because of sudden loads, it evens things out, smoothes out torques.
2. It stores kinetic energy which aids in crank rotation.
So would a bigger flywheel give you better torque and a littler one more high end power:ponder:
A lighter fly-wheel allows the engine to spin up more quickly. This allows for the power to go from engine to drive train more quickly.
A heavier fly-wheel takes longer to spin up, and thus slows the engagement of the drive train.
Note that in both cases the difference is negligible and may not even be noticed.
Now, on the top side...
Once the engine is at full rpms the heavier fly-wheel will remain moving longer than the lighter fly-wheel. This means that you can actuall coast a little on the top after letting off the gas. The lighterer fly-wheel tends to slow quicker and require more hits on the throttle to keep it up there.
As for more torque or power, the only way to get more torque from your engine is to change the gearing. Your engine will generate so much torque at a certain rpm....this is fairly constant dependent on the rpm. Meaning at 20000rpm the torque output is one number, and at another rpm it may be the same number or another...but it will remain the same for that number.
As your engine gets older and the internals get worn, you will see the "power" drop off as the engine tends to lose compression and "slip."
edited to include corrected information...what was I thinking? Thanks Krusty for the catch.
Originally posted by SkyMaxx
Once the engine is at full rpms the lighter fly-wheel will remain moving longer than the heavier fly-wheel. This means that you can actuall coast a little on the top after letting off the gas. The heavier fly-wheel tends to slow down the engine quicker and require more hits on the throttle to keep it up there.
A heavier flywheel, once it is up to speed, will remain in motion LONGER than a light flywheel. A heavier flywheel has more mass and inertia, thus will tend to stay at a given speed, unlike a light flywheel. A heavy flywheel takes more energy to get up to speed, but it will store more energy and release it for a longer amount of time.
Good correction. I was almost asleep when writing that response. Thanks for getting me straight.
