I keep one of those in my pit-box/tool bag and I use the gel at my bench:
https://www.amazon.com/Permatex-24010-Strength-Threadlocker-Applicator/dp/B000HBM564
Also use orange for things I don't want welded (ie use red), but want a bit more holding power than the blue gel gives me:
https://www.amazon.com/Permatex-25210-Strength-Removable-ThreadLocker/dp/B07R6B87S5
For grease, I use lucas red-n-tacky:
https://www.amazon.com/Lucas-Oil-10574-Tacky-GREASE/dp/B0049SUK5Y
I only really use that on steel internal transmission gears and differential ring/pinions.
I use wax based lube, white lightning clean ride for everything else:
https://www.amazon.com/White-Lightning-Bicycle-Clean-Cleaning/dp/B07XX6YD51
Hinge pins, spur/pinion, cvd cups/joints, axle sliders, etc. Tried the Epic Ride version and didn't care for it as it never completely dries. The dry wax lube doesn't collect dirt like wet lube/grease/oil does.
I use standard old 3-in-1 for my bearings.
