xp190
Hi Guys
First time poster as well as first time Nitro RC owner.
I have a few general question which I would like to hear some comments on.
I bought a TMAXX (4908), used, from a guy who raced RCs for years.
The truck other than a few broken pieces was in decent shape.
I rebuilt it, replaced all the broken parts, cleaned it up good as new, put it back together, fired it up and it ran quite well, but I had a hard time tuning it just right.
It would bog down when I richened it a bit, and stall out when I leaned it just a tad, I figured most likely an air leak, so I replaced some orings, and sealed the engine. It holds an idle much better since, and is easier to tune.
Here is my issue.... Starting.
I watched some youtube clips and it seems nitro engines fire up almost instantly and run quite well, mine wont do this. I have the EZ Start system, and in order to get the motor to run I have to spend 2-3 minutes spinning it before it slowly starts catching, and eventually it will take, this is after priming the engine, so I know fuel is in there, just not getting burnt.
How hard is it to start a TRX 3.3, once it is broken in, on a cold day, say 10C, which would be 60F or so? I find it very frustrating that it takes so long to get it going.
Once it is running, It has plenty of power, I'm still working out a few tuning issues, but I think it should be fine.
Second question,
The engine seems to be leaking fuel through the EZ Start system, not the back plate, but the shaft, unless I missed something, it's quite a bit too, so it might just as well be suking in air through there, is this normal? Is there a way to seal it, or just replace? I ask because the truck gets real filthy because of this, and it's a hard to clean place.
Some more information for you experts.
I took the engine apart, it has lots of pinch at the TDC. I put in a new glow plug and it seems fine, but I'm going to start using a glow ignitor as opposed to the traxxas EZ start for heating it up, maybe it will help with the starting.
It seemed to run a bit hot at first, hence the orings and sealing the engine, it is doing much better now. I have a new fuel tank, so there should be no air leaks there, and fuel lines check out as well. Exhaust is sealed off nicely.
My main concern is starting it, if this thing had a pull start on it, I'd rip out at least 3 pull starters before it fired up, I'm glad it does not right now, but this can't be normal, can it?
Thanking you all in advance.
xp190
Second question,
xp190
