The tranny case isnt even that heavy. Its all plastic except for the motor mounting plate and the heatsinks.
The heatsinks work because the metal motor is touching the metal mounting plate which is in turn touching the heatsinks. So how much it works is debatable because none of us has actually tested it but they do work to some degree. That much is fact, its science. Dont believe me? Look up
Fourier's law of Conduction and Thermal Resistance. On top of that you can still put a fan on the motor. On top of that the fan doesn't do a whole lot when the car is moving, its more for cooling the motor at slow speeds or when stopped. When the car is moving the heatsinks and the aluminum plate are pretty effective at dissipating heat, more so than the fan is because more air is moving past the motor and its connected heat dissipating plates/heatsinks. If you think the fan is doing much when the car is moving at high rates of speed then think about it like this. If you were in a parked car learning out the window holding a fan in front of your face it you would be able to feel it just fine and would have a nice cooling effect on you. However, if you were going down the highway at 70MPH doing the same thing you wouldnt feel the fan at all over the air moving past you due to your forward momentum.
As for how you think it looks, I'm not sure what that has to do with the debate because were talking about whether or not heatsinks are a gimmick, not how the case looks. That is a red herring argument and therefore a fallacy.
I'm happy to keep debating this is you wish but I think I've proved my point more than adequately.
I agree with you 100%.
I don't understand why couple people got upset, I would assume they don't work for hot racing, so who cares what I think.
Metal transmission case looks like it is one piece and it's a big chunk of metal, even with no airflow it will take some heat from the motor. Let's say transmission case acts like a heatsink, I don't see adding 3 more heatsinks attached to a heatsink effective.
On nitro cars, aluminum chassis acts like a heatsink and will reduce some temperature, there is no doubt about it, but attaching extra heatsinks to the chassis to cool it is unnecessary and pointless.
The point what I wanted to make, if you dont have excessive heat issue, reducing motor temperature by a degree or two in the best case scenario will not make any difference. If you have excessive heat issue and motor is running 200f and over, those 3 heatsinks will not solve the issue.
You are.right about the fan, it will help when there is not a lot of airflow. In my b6.1 buggy I have both carbon and aluminum motor mount. I tried both and when it comes to temperature there is no difference at all, but like you mentioned, buggy has enclosed body with not a lot of airflow so without a fan you will cook a motor in the matter of minutes, especially running on high traction carpet track. Short course has an open body and some airflow but still not enough. But for race cars you have to run agressive timing and relatively tall gearing to keep up with the rest. For bashers I run stock gearing, or if an aftermarket motor, I run gearing to get me to about 45mph on 3s, and never overheated a motor.
Although I would never spend 54$ on transmission case because I never had any issue with stock case, and I don't want to add any extra weight, especially behind rear axle. I have to admit, the case itself look really nice, machining looks awesome, and I like black "stealthy" color with some raw aluminum lines. But those 3 blue heatsinks look kind a childish to me, and they reminded me like some kind of transformer or inductor coils.
Awesome race today
When I mentioned nitro, last week I bought nitro rs4 Evo+ 3 for 50$. Awesome shape but missing a tire, axle and servos
It looks like it's all metal, at least that's what they claim
