• Welcome to RCTalk! šŸš€
Time for something new
DavidB1126
Team Bomb Pop
Bomb Pop Island
Been rocking between 2 Traxxas anaconda truck tire sets for well over 3 years which are worn down to nothing. Time for something new. Traxxas sct rear offset wheels on all 4 with Proline Hyrax SCXL tires, thanks to @Serea71 😁.
Tested them for about 5 minutes before sun set. Good grip on road and in the grass! Had to adjust my slipper as it was a bit loose. Don't wanna ruin a transmission again by not adjusting the slipper, I learned that the hard way šŸ˜…
Got camber fixed and aligned. Now I just got to figure the toe. I think I need to have the wheels pointing more out for it to go straight without needing to putting my servo trim to -120 which with that, the turning radius of turning left is huge. šŸ™„
I think Traxxas has a diagram of the turnbuckles so I'll see if I can find that in my manual bag. But since of the new rpm offset arms add about 3mm of width, 🤷
I think every RC suggests +1 degree of toe. I know he'll to adjust it, by the turnbuckle, but there isn't really a toe gauge out there. There's a complete setup station. But those are for 10th / 8th scale race kits and there's none oriented to bashers. I just try to eye it most of the time.
Alignment done. Not perfect but it drives straight šŸ™ƒ
Might need to raise the rear body mounts
But besides those little things it seems to be running pretty well. Drives through the grass easily. They a bit noisy on the road though, but that's normal with off-road tires. Under hard braking is when it gets loud lol.
Then you come over and mow! My uncle stole the mower.
Whats your address? I've got some dull body scissors you can get started with!
I'll send them to:
David
On corner holding sign
Hobbytown, USA 12345
šŸ‘šŸ»
Looks good!
RPM used to make a nice, cheap toe gauge. Did they stop making it?
Yep, they still make it.
https://www.amazon.com/RPM-70492-Toe-in-Gauge/dp/B0006O7O0Y
