Ok, here is what I would use if I were to build one. @Xraycer can chime in on this if he has any changes he would make. Keep in mind... cost is no object here. If I build this, it will take me a year to finish it more than likely.
Chassis: Showtime by Gamyrc. I would also make sure to get this in nylon.
https://www.shapeways.com/product/2DXEA9XAZ/showtime-scx24?optionId=140082440&li=marketplace
Motor and ESC combo: Furitek Stinger
https://www.furitekusa.com/products/furitek-stinger-brushless-power-system-for-scx24
Axles: Treal
https://www.trealhobby.com/products...-7075-diff-housing-for-1-24-scale-elec-4wd-36
https://www.trealhobby.com/products...using-for-axial-scx24-deadbolt-c10-jeep-betty
And while there I would also grab some Deadbolt high clearance links, steering knuckles, Deadbolt drive shafts, shocks, +5mm hubs, steering link set, and the crossmember.
For steering duties, I would use the Ecopower 827, along with the Hot Racing servo mount.
https://www.amainhobbies.com/ecopow...ear-micro-servo-high-voltage-ecp-827/p1310408
https://www.amainhobbies.com/hot-ra...er-steering-servo-mount-hrasxtf24m01/p1234773
For wheels I would go with aluminum/brass ones from Little Guy Racing.
https://littleguyracingparts.com/products/team-raffee-co-aluminum-beadlock-wheels-w-brass-hubs
For tires I would use Trail Kings from Little Guy as well.
https://littleguyracingparts.com/products/trail-king-m-t-1-0-tires?_pos=1&_sid=9dc37d8d1&_ss=r
You are officially my favorite person of the day! Thank you so much!
Oops! thought the thread was 'what did you do today' instead of 'what did you buy today'. Well, I bought something illegal. It cost $220 and weighed 1 ounce. It was for a friend
Sounds like a good time. Price seems low.
You are very welcome. There are other chassis on Shapeways that are very cool. And Little Guy has an Ulta 24 chassis that is pretty epic as well. Little Guy also has portal and extended axles in the works. Very excited to try those. And moforc.com has some killer stuff as well, like a worm gear to make one of these into a 6x6 if you are feeling creative.
All in all, these trucks seem to have more mods available for them than any other RC. It is a bit overwhelming, because I could build 100 completely different trucks if I just had the funds. I am actually planning on getting pretty crazy with some builds as soon as I get caught up on a few projects.
These will go well with the Mud Slingers I am going to buy for the rock racer.
Too many pics to post for what I bought today but I ordered a bunch of stuff.
1
EMAX ES08MAII 12g Mini Metal Gear Servo for SCX24
Hot Racing Aluminum Gear Box Cover Axial SCX24
Hot Racing Aluminum Skid Plate Axial SCX24
Hot Racing Aluminum Transmission Case Axial SCX24
Hot Racing Black Aluminum Steering Rod Set SCX24
Hot Racing Steel Center Driveshafts for Long WB SCX24
RC4WD Mud Slinger 1.0" Scale Tires
Hot Racing Brass Stock Wheel Hub 7mm Hex SCX24
Hot Racing Brass Weights for +4mm Steel Axles Axial SCX24 (4)
Axial SCX24 Front Axle (Assembled)
Axial SCX24 Rear Axle (Assembled)
Injora high clearance links.
I'll order some aluminum axle housings some other day.
I also noticed some wear on my front tires of my real truck so I had to go down and get a front end alignement and tired rotated.
1
Let me know if that trans and gearbox cover work on the Furitek trans when you get it. I was wondering about that.
Yeah, I'm not sure but I will soon find out. It wasn't very much so if it doesn't work out, I can use the parts on something else someday.
I'm gonna print you a stand for it as soon as I know what you are doing with it 😜
Very cool, thanks man.
This is a shot in the dark for me and may be a stupid question but the Stinger I ordered, can I use my spektrum TX/RX with it or do I have to find the scx24 TX/RX?
You can use your own Rx with it, or if you buy the stock Tx/Rx, you can tie the Liko Pro into it. The Liko is just an ESC, but they have made it to work either way, as a compliment to the stock system, or separate radio setup. It will not however work with the newer Rx/ESC combo that comes with the newer SCX24's, like the Gladiator. Horizon has F'd that all up now.
1
Dude! that thing is going to weigh 5 lb.s when your done! :p
Haha that may be a good thing.
Ok very cool, thanks bro. I just wasn't sure.
