- Thread starter
- #281
My post in the "What did you buy today?" thread is a spoiler for what comes next.
I still haven't resolved the design for the bullet connector boots, but I want to make progress. I figure I can solder and sleeve them up and mold or attach the boot later.
These ones go all the way to the PCB, so I can have very clean ends.
Nice stable base for the bullets. Again with the very biological clamping.
And look at that. Some slack I in the A channel (blue) that I'll take out.
You'll also notice that the B channel (yellow) is a lot shorter than the other two. That's because I could not for the life of me get solder to stick to it where it had been embedded in the RTV rubber during those test casts above. Flux, super high temperature, burning the rubber off, none of that worked. I had to cut off the end and tin it fresh.
So the yellow is already just barely long enough, and then I used it as the guide for the length of the blue one.
And now the newly shortened blue wire is too short. It's not just a cosmetic issue, I can't even lay the ESC flat in the chassis. This is what you get for not taking your time and thinking about each step.
So...
Do I just replace the blue one with black? Or do I do them all for an even cleaner look, and take care of the capacitor at the same time?
So...
