SchrodeMode
Active Military
I am getting this info for a friend and I'm not 100% sure on his set up, but I know the basics. It's an older 3.3 Maxx (short chassis had reverse) that has the wide RPM arms on it, he put the OS .21TM in it and after his stock drive shafts went he threw the steel ones from Traxxas on it (center and outer). He had the problem with the outer drive shafts falling out of the cup, it actually broke the pressed in pin on his first run, fixed that with the extended cups. Now the cups are notching the pins that the cups make contact with, the "T" part, and his center shaft is barely sitting in the cup. If he shims it, it goes too far and locks up. I've told him to adjust his slipper and he told me he did, I've also told him to never land while on the throttle and he said he doesn't. I'm not sure about the slipper but I think most of the damage is because of his jumping skills (or lack of), next time I see him I will try to check the slipper. I'm just wondering if the Traxxas steel shafts are known for being weak, I told him to try pressing a stronger pin in after they break but I think that will eat the cups. He said something about people using HPI dogbones, anyone heard of this before and if so do you know which ones? I am also going to see what his gearing is, I think he needs to up it a little. He just ordered an extended chassis Maxx roller, it will get the .21 and he is going to throw a Dynamite .19 on the short chassis.
Thanks in advance guys.
