So, I'm gonna' get a metal ammo can and a lipo charge bag...
RudyF6
In a holler on a lake, Chelsea, MI
  2. Crawling
And here's why.
This is from my Redcat Shredder. 2s, uses 2 in series. Started dying under heavy load like it was hitting lvc. Bought 2 new ones and problem solved.
Forgot the originals were just sitting in a parts box, a plastic tub full of cardboard boxes and surrounded by fuel sources. I did not put that in there like that, it's been probably 2 years. What's weird is both batteries show the same storage charge at 3.7 and the other one is fine.
Did I just get lucky finding this?
What should I do with them?
Google search lipo disposal sites local to your area. There's several located near me that take them for free, regardless of condition.
Also, NEVER leave lipos in a box for years at a time without checking on them. Always store in fire safe bags. You got lucky. Don't push it.
The problem with ammo cans is they aren't vented and pressure could build up and cause an explosion. That can easily be fixed by drilling holes in the can but then fire can escape through the holes.
I'd recommend vented ammo cans with the lipo's inside lipo bags inside the cans. Thats pretty much what amain is trying to sell you for $100.
That makes sense.
I'll be shopping now, maybe you'll see a "What did you buy today" post!
I use a fireplace ash can, along with lipo bags. It's large enough to hold batteries and charger.
I like that the bat-safe has a filter. In the lipo fire that a club member just had, the structural damage was limited to one garage wall that unfortunately included his breaker panel, so they were out of their home for a couple of weeks. The soot created a real mess, and cleanup of that is the biggest task, pretty much coated everything in the garage and into every nook and cranny. If the filter could really trap most of that it would be well worth it.
I have had two swollen batteries, one in my laptop that popped the touch pad up, another was a jump starter that I am sure got very hot being stored under the seat in my truck. In neither case did the batteries generate any heat.
Currently using a LiPo bag in a small refrigerator in my garage. Was using double bags and 50 cal vented ammo box, but it gets too warm (over 90F) in the summer in the garage and don't want to keep it in the house for obvious reasons. Might see if I can install a thermoelectric cooler in the bat-safe or equivalent. Again, the filter is a great addition if it has enough capacity.
One thing is I think most of us are storing several batteries together but that will just make for a bigger fire than a single battery so that is another dilemma.
If you go the ammo can route, make sure it is sitting on something that can withstand high temps, like concrete, cinder blocks, etc., it won't do you much good if the heat melts your carpet or catches wood floor on fire (metal gets hot!).
I think home Depot takes them for a program. Mine near me does it.
Yep, mine are in the basement on the concrete slab.
