setup board for nitro revo
ThunderTiger
London (U.K)
As per title, is there such a thing as a setup board that can be used on the nitro revo (2.5 or 3.3)?
I used to know such things, but time away has seen a few things forgotten.
I need/want to ensure I get my revo perfectly setup in camber and toe and that all wheels are aligned properly with each other before I run for the first time following the build.
I have a while yet before I need it, but it would be nice to have it there ready to use.
I can set everything else up without specialist tools, so that is tnot an issue.
I've only ever seen a full blown detailed set up kit for on road cars. Thats being said others may exist but I've not seen one. I just use camber, toe, and droop gauges. Its not quite as exact as a full blown board like I've seen for on-road but I dont think off road kits need to be that exact. Id be interested to know if their is one for other kits though if someone knows of one.
looks like I need to make one then.....
Easy enough with a little know how ;)
I like to know that everything is setup straight to begin with.
I can then set up how I want from there knowing everything is uniformly set from a pre-set base setting.
So it looks like I need to sort out a few parts, source a base and organise some time to build the thing!
I see what you mean :) Maybe you could sell your creation for $100 each, you'd be rich...if anybody bought it.
if/when I build it, it will be using easily obtainable parts and cheap.
It only needs to give a way to set front wheels level, show camber, toe and caster for all four boots.
Even going down the route of balancing the rig fore to aft, left to right and across diagonally opposed corners.
once I'm happy the rig is setup straight and balanced, I'll be happy to run it.
Sounds good.....
maybe one day, your product will make you rich :p
nope, not into that game. Prefer to make what I need and use it.
E
Replies
1
Doom!
Doom!
J’sCrawler
Replies
18
J’sCrawler
J’sCrawler
R
Replies
11
3K
Nightcrawler67
Nightcrawler67
HDRIDER56
Replies
30
2K
HDRIDER56
HDRIDER56
