You are going to be extremely rich. If the motor has been broke in, set it to 4 out, then lean it about 25 minutes. Flush the low speed.
This will be on the rich side still on the hsp. Once you get the hsn set, with an idle gap of 1mm, if the idle is high, adjust it with the idle screw. Not the lsn.
Personally, once I set the hsn, I’d run 1-1.5 tanks through it without adjusting the low end of the motor. As long as it will idle and it’s not so lean it moves on its own. If it’s set that long, it might take a couple tanks before it settles in good if the motor wasn’t taken apart and cleaned well before reviving it.
