Select ESC and motor for 1/8
mar
I need recommendations for ESCs and motors for a 1/8 scale dragster, pls
Welcome to RCT
I have used Spektrum and Hobbywing in my 1/8 models (Truck, Truggy, Buggy), but don't have a 1/8 dragster, so not sure on that. Likely there are drag specific ESC/motor combos out there, and I'd guess probably the highest ESC current and motor KV rating you can pair.
I know the Hobbywing XR8 can be had with a 2800kv motor, and for a budget setup, the Max 8 comes with a 2500 kv
Welcome to RCT!
Typically, RC electronics are designed to be used with certain scale RC cars/trucks in mind. So if you went with a Hobbywing Max8 combo, that should do it. But it depends on a lot of factors.
I don't know of any 1/8 scale dragsters that aren't custom built. Is yours a custom chassis? If not, what is it?
Weight will come into play, as well as your final drive ratio, rollout, pinion/spur sizes, etc. So you're going to have to give a lot more info to get a good recommendation.
And share some pics, or links to what kit/custom chassis you're building.
Good points.
In my Associated DR10, I run a 100A ESC, a 3900kv motor with a 26T pinion and 78T spur, none of which are as it comes from Associated.
They send it out with a 60A ESC and a 3300kv motor spinning a 18T pinion and 87T spur
Good points.
And it's slow as hell on 2S. It rips on 3s pretty good though. How do you like that setup?
I for one can only guess what ESC requirements you would need and for what type of surface you would be on. Not enough information to come up with a game plan yet. I'd probably reach out to a dedicated group for the type of 1/8 scale draggin' you are doing. Rules? What are we playing with?
Possibly a 40x127mm motor in your future? :D
For now, too many unknowns.
RCTalk's category... No Prep Drag Racing
Let's work it out.
Welcome to the fold!
It's fast enough for my driving skills, and I like it a lot better than the stock setup.
