Question: How can I reverse my servo?
Answer by peepee Pettit
You can reverse a servo quite easily, if you have expertise in soldering. Use a small iron, maybe 15-20 watts with a very fine point, and use rosin core solder only. Get help from someone who has experience.
Open the servo and reverse the 2 wires going to the motor. If the motor is connected directly to the PC board, close the servo up and buy a reverser.
You also have to swap the 2 outside wired on the potentiometer, which is WAAAAY down inside the servo case. There are 3 wires, just reverse the outer 2. If you don't feel comfortable doing this, buy a reverser.
If you completed the 2 wire mods, take your soldering iron and etch a big "R" into the case. This'll remind you that this servo is reversed.
Answer by Kirsch
You buy a servo reversing harness, which is just a short extension with a small bit of electronics that reverses the signal to the servo. Simply reversing polarity is a bad thing, or so I've been told.
http://www.wwcn.org/~grit/faqs/airmodelsfaq.html#question:How can I reverse my servo-
thats what i read and it was for airplanes but should be able to work on anything
but as said before if your good as soldering i would try it on a cheap servo before doing it to say a 50 or 100 dollar servo
