- Northeastern NY
- Crawling
- Scale Builder
- Flying
- Boating
- Thread starter
- #41
No problem my friend!
Your help took a big load off my mind (and saved me some cash). I was finally able to install the receiver, bundle and neaten up the wiring and declare the project complete. In about two or three months, the snow should be gone here and I'll be able to get the Optic outside on the rocks behind my house.
Just a few notes on the build...
I've seen a lot of kit-built Optics in videos that had really horrible drive train noise. Mine is not noisy. Be sure to add one or two of the included shims as needed between the drive shafts and the differentials. I believe I used two shims on each. When I had assembled my axles, I applied some pressure to the input shaft while turning it. It was noisy and rough with pressure but smooth without. The shims stop the driveshaft from putting that same pressure on the differential's input. (No shims are needed on the transmission end even though the instructions mention it.)
The instructions don't mention clocking the universals on the drive shafts to the same position as the universals on the transmission. Having these in sync makes the driveline run smoother.
Now, the long wait until Spring!
