TRX-4 Shift Servo help!!!
gsemeraro8
  1. Crawling
Hey guys,
I got this little trans shift servo, But I need a new servo saver…What size would this gear be? The stock traxxas servo saver is wayyyy too big and the listing says its also 25T…I need the servo saver with the stud on it that fits this, Any help would be greatly appreciated!
Here is the amazon link!
https://a.co/d/bPtTi0T
Do you have calipers? That should use a standard micro servo horn. Check the gear diameter. It should be around 5mm diameter. Then count the splines (teeth). It should have 25 teeth.
What you should find for the Accent is a 25T gear @ 4.9mm.
The Traxxas TRX4M should have [email protected] diameter gear.
This should work, but make sure
https://a.co/d/0UeLU6o
you are the best! Thank you, I've never worked with mini servos before, I gutted the original ones out of the diff lockers and made them permanent lol
