Rear Shims on Slash
godale03
Awesomer!! Than Rolex!!
Maryland
Hey Guys,
I was taking apart my Slash yesterday to clean it. I was in a bit of a hurry since time never seems to be on my side... anyway there are two shims that went somewhere on the rear axles. It is a thin and think shim. Which side of the carrier to they go? Does one go on each side of the bearings? Or do they match up and go between the bearing and the hex? I can't tell from the exploaded image, it just shows one shim between the hex and the outside carrier bearing. Thanks
Tom
godale03
Maryland
Afternoon Bumpity Bump!
marauder
Hardcore RCNT User
Tampa, FL
  1. Racing
If I buy one tonight I'll look at it and let you know.
godale03
Maryland
Just took mine apart to check. Thin inside thick outside.
Thank you!! I figured one went on the inside and one on the out.. but just wasn't sure which one went where. Thanks again!
Tom
