sweetdiesel
aka SouRGassssssss
For my winter project I wanted to try stretching out the Goliath to make it a dedicated crawler. I got most of my ideas from the guys at one18th.com. I'm about 1/4 finished with what I want to do. Here are some progress pics.
Current wheelbase is right around 8 inches, when I'm done it should be about 10.
The wheels are HPI super star rears. They come with hex adapters which fit the wheel pins of the Goliath perfectly. The tires are 2.2 masher 2000s. I'm not sure if I want to stick with the revo cants or forgo the cants altogether and mount the shocks directly to the axles. I'll also flip the front and rear diffs so the battery is over the steering axle for more weight over the front tires. It should help it climb a little bit.
I'm going to mount the skid plate about 10mm rearward. Rear skid is on the way also. Eventually I'm make it RWS soon as I can figure out how to activate the rear on demand with the 3rd channel of my 3PK.
Stock steering set-up sucks on the Goliath, I bent up a revo rear toe link to 128mm and took off the servo saver. Now it steers more sharply and evenly left to right.
The 4 links are all traxxas, 121mm lower and 95mm upper, with a RC10T4 cvd. I'm working on a one piece mount which will relocate the steering servo to the top of the axle and also mount the upper links closer together on the axle with the rod ends in a vertical position. The way they lay flat right now hinders their movement.
Once I stretch the rear and get the links worked out I think I can get close to 90 degrees articulation. I'll be adding a 6 cell pack, better esc, and a lathe motor for more torque. I plan on running as small a pinion as possible, looking for a 12t right now. The radio plate and battery tray will also be aluminum. Once I play around with it a bit I'm going to try and improve on the side chassis plates. They look fugly!
Well...hope you enjoy the pics, so far this has been a fun little build.
