TasUK
hi all, i am new to the forum and would first like to say hello!
I need help with my Orion Wasp .28, i have run 6 tanks of fuel through it so far and at top end it's faultless! however i cannot get it to idle and off throttle it tends to load up and die, i have look around for an instruction or manual and have had no joy finding one to reset to factory settings.
all the sites i've looked at so far fail to mention the fourth screw under the high end needle? the engine is not a Picco and is a Orion wasp .28, it has a blue housing and a silver circular symbol on side of it. there are four screws to adjust the carb setting, 1)an idle screw 2)low end screw 3)top end screw 4)fourth screw under the top end screw/tower facing outwards from the carb.
the engine has good compression and works while on throttle perfectly, in a big open area it's fine, but i really want it to be running well across the board.
i bought the engine on ebay, so i have no manual or guide to help me, can anyone either direct me to a manual or offer me helpful advice please?
thank you for taking the time to read my problem.
