Need linkage help.
easy rider
I’m looking for a supplier of throttle linkage parts. I need some slides particularly. But, would love to know where to buy them. Any advice welcomed. Thanks.
Just an fyi Incase anybody ever google searches for savage x linkage.
I used part of a tmaxx 3.3 linkage. The push rod, two collars, and the return spring out of the tmaxx linkage kit. I also used two sleeves I bought from dubro’s. 3/32 sized. I drilled those out bigger to prevent binding and walllah!
I’m currently waiting on a new rx/tx combo that allows me to set throttle end points. It’s a have to do since redoing the linkage will throw the push rod about 2.5 times what’s needed when accelerating.
But, it works very well. I stripped the spur on tank two on breaking in. I knew it needed a new one as it has a rough spot. But, you do what you gotta do when you gotta do it!!
I did use the brakes but, I’ve got to adjust them when I install the new spur. So, I took the tubing off until then.
