ohsnap
- Edge of the Piedmont
- Racing
That is definitely a problem!
Here's the part that you need.
The HPI part number is 1481 and correct for the S-25 engine.
Currently available on eBay.
https://www.ebay.com/itm/126550198254
You also need the 2 orings (HPI part number 1469 - comes as a pair).
One fits in the groove at the bottom and the other rests at the top of the neck (seals the top of the throat).
Don't know, don't care what youtubers say...
Same goes for AI responses while I'm at it.
I quoted you the HPI NItro Star S-25 manual HSN and LSN settings.
To complete the manual's guidance - here's what it says about the LSN.
"After break-in, the needle setting can range from 2 1/2 to 3 from fully closed depending on humidity, elevation, fuel, and glow plug."
Yes - it is the same statement as the HSN's setting...
All the videos I saw from you said that hsn and lan are both flush with their housings to go to factory.
