Well, usually plastic/composite spurs hold up pretty well. They normally fry due to a hard engine hit, blown CB bearings, bad gear mesh, cracked or loose engine mount, loose engine mount bolts or too loose slipper setting causing excess heat to melt it.
Buying steel can cause other issues. Swapping out a spur is pretty easy. Swapping out trans gears, center axles or diff gears can be a bit larger of a job. The spur is your easy to fix weak link to those other parts.
I'd just try and figure out what caused your current spur to fry and fix the issue.
When you buy a spur, buy 2.
If you do decide to go to metal, you will need to find an aftermarket hardened bell or you will toast your stock bell. It isn't designed to run against a hardened steel spur and it won't last very long at all. I have photo's if you need proof. Sheared all the teeth off in less than a tank! Looked like I went after it with a grinder!
