New Monster Truck Tires?
You could probably stretch them to fit on the USA-1's wheels or make them fit somehow. Anything will work if you peepee around with it enough.
i think they will fit are the hubs on your usa 17mm ?if they are just buy a set off ebay with rims much cheaper. the usa-1 was based on a buggy chassis kyosho and i think it did have a 17mm hub good luck!!
(I think they will fit are the hubs on your usa 17mm ?)
can someone fined a tower hobbies link that sells the rims & tires for the onfa Titan i can seem fined them?does the Onfa Titan have 17mm hex hubs?
yes I am prity sure they are ill have a look and fined out.
D :idea: oes any one know some realy good rims and tires that fit 17mm hubs?
thanks for your help fellas.
Regards Matt
ok this will confrim the 17mm hubs SPECS: Length: 19-1/4" (489mm)
Width: 17-1/4" (438mm)
Ride height: 4-1/2" (115mm)
Black rubber tires with foam inserts
width of tire: 4.5" (114mm)
Satin chrome rims, uses a 17mm hex washers
outer diameter of wheel: 3.0"
do you want big tires or a low profile race tire? dominator has so awesome rim & tires that i use on my savage
