New Losi tenacity DB pro
Register Log in
Bizzle
RCNT Rookie
Good question. Any chance you can physically measure the stock one and follow those dims?
I could, however would that mean I have to get a servo that matches these specs exactly? I see the Savox 1258tg is popular for these rigs but its not waterproof. This servo doesn't match the specs of other servos I've seen used in the pro either.
I suppose I'm stumped in general sizing of aftermarket "standard" servo sizes and what tolerances are deemed acceptable.
42mm seems tall and the 29.2mm seems like it would tower over the mounting points in the stock servo mount.
E-fanatic
RCNT Racer
Hertford, NC.
Bashing, Racing, Flying
I have the savox 2274 in one and the 2271 in the other. Both are great. If you like massive torque and decent speed get the 2274 if you like great torque and super speed get the 2271. Both are the same spline as the stock servo so you don't have to get a new servo arm
Bizzle
RCNT Rookie
Savox seems to be the way to go given the research and your recommendation. However, the ones you have are not waterproof. There are ways to waterproof servos but something just seems janky about pulling apart a nice new servo and loading it with grease and plastidip.
E-fanatic
RCNT Racer
Hertford, NC.
I don't submerged my trucks. So a fully water proof servo wasn't a priority for me. The standard rubber seals is enough to keep splashed waterout for me. If you are going to run say in the snow of through mud puddles then the savox sw1211sg would be a solid choice.
Its a little taller than the 2271 but the supplied servo isolators that come with the servo will take up that extra few mm.
Bizzle
RCNT Rookie
So I broke the rear hub on my dB pro. It's tough to find replacement hubs in Canada, so I was hoping the SCTE hubs were the same?
They looked ok similar but I can't be sure.
Bizzle
RCNT Rookie
Bizzle
RCNT Rookie
I'm looking to "Truggify" my DB Pro. I've got a lead on a set of cheap proline badlands mounted for a 4x4 stampede with 12mm hexes.
Has anyone successfully ran MT tires with their Tenacity on stock pinion? I'm running 2s, so I don't want to sacrifice too much speed dropping a pinion but also want to keep temps in check.
Thought I'd check in to see if anyone has experience.
Thanks!
brushlessrc
Hi all, new to the TT/DB pro, was wondering if anyone found any aluminum ball ends for the shocks? Also question about the servos. The stock s605 servo is 23 spline and the savox 2271 is 25 spline. I don’t understand how the savox can with the stock servo horn? Thanks.
Bizzle
RCNT Rookie
Hey! I just installed my Savox 1210sw today, what a much needed upgrade! All you need to do is buy the servo and a 25 tooth servo horn, remove your old servo and servo horn. Done deal!
If anyone was wondering the waterproof 1210 fits perfect.
What does not fit perfect is the aluminum rear hubs for the scte. The hub itself is exactly the same as the tenacity hub, however, the scte hubs do not come with the required shims.
I bought the scte rear hubs and wasted my money as I had to buy the tenacity rear hubs that include the spacers/shims.
brushlessrc
Thanks for the info and update. Sorry to hear your hubs didn’t work out. I bought a savox 2271 and a 25 to 23 servo horn insert. Hopefully it works. The servo comes on Monday. In case the insert doesn’t work, would you mind sharing what servo horn you got? Thanks!
Bizzle
RCNT Rookie
That insert should work for you but I'd recommend an upgrade to an aluminum servo horn anyway.
There has been success with the Losi 25 tooth horn, but I opted for the hd power 25 tooth clamping horn. I needed a longer screw to make it work wth the bell crank arm (m3x16mm), but it fit perfect and works great.
brushlessrc
Thanks!
Bizzle
RCNT Rookie
I found out I bent my wheel where the wheel nut meets the axle...
Weirdest wheel damage I'm ever seen, the hexes were 100%. As you can imagine I had some crazy wheel wobble because of it.
I went out and got the premounted proline badlands with offset #1173-12. These fit perfect on the Losi hexes and are a huge upgrade from stock tires. Just a tad bigger too.
Ran a full 2s pack on the stock pinion and my motor was warm, not hot. Perfect set for this rig in my opinion.
In case others were interested.
Uncle Pete
North Central MA
Bashing
Hi All,
Starting to shop for items for my soon coming Losi Tenacity DB Pro. So I would like to ask, what you would recommend for a novice for choice of batteries. Should I go with 2S or 3S.
I want to get the most out of the buggy, and still have good control over it. I don’t know if the 3S will push it to far for me.
Also is there a setting on the transmitter to control the amount of power going to the motor. Great thread by the way.
Thanks in advance for any assistance with this.
Uncle Pete
Bizzle
RCNT Rookie
Hi All,
Uncle Pete
I was heavy into RC almost 15 yrs ago, just as Lipo and brushless was really taking off. My daughter showed interest after I bought her a Traxxas Stampede, so you know, I had to get something for myself.
After the same battery size debate myself, I opted for a 2s batt.
-Easier to get used to. This thing is quick.
-Easier on the drive train as I refamiliarize myself with diffs and drive train parts.
-Battery works with my daughter's Stampede.
-I live in an urban environment where open spaces are limited to get the most out of a 3s.
At some point I may go 3s but I'm having a lot of fun on 2s.
Thread starter Similar threads Forum Replies Date
F Losi Tenacity DB Pro Tie Rod End Upgrade Question Buggy and Truggy 1
D Losi Tenacity DB Pro - What common parts break? Buggy and Truggy 18
F Associated rc8.2e rtr or Losi Tenacity db pro Buggy and Truggy 7
W Upgrade Motor for Losi Tenacity DB Buggy and Truggy 6
Bronco6L Losi tenacity truggy overheating Electronics 5
E-fanatic Losi tenacity truggy Buggy and Truggy 44
T Losi Baja rey 1:10 vs Losi Tenacity-DB 4WD 1:10 Electric RC 0
StephMir Losi Tenacity Desert Buggy Electric RC 8
Horrells Losi tenacity aluminum upgrade Buggy and Truggy 8
N Losi tenacity MT Monster Trucks 13
T Losi Tenacity MT/DB/SCT/Truggy Electric RC 30
WoodiE Losi Tenacity-DB 4WD desert buggy Buggy and Truggy 6
thebat1971 Losi SBR steering problem Short Course Trucks 2
O Losi ten t Nitro RC 5
Backtothefuture Losi Mini T- e clip size, also brushless recommendations. Mini & Micro RC 0
Bluetickduke Losi 5t 2.0 VS Rovan 1/5 Large Scale RC 12
Bluetickduke Losi 5t 2.0 Large Scale RC 3
Backtothefuture Losi XXX-S Drive belt - UK Electric RC 6
Kylec345 Brand new losi mini 8ight truggy issue Buggy and Truggy 0
Backtothefuture Losi Mini-T (original) batteries. Mini & Micro RC 2
GMCK1500shoptruck Brother in law’s Losi Short Course Trucks 8
Marinedan The super rock rey losi should have built. RC Builds and Projects 8
Marinedan Losi super rock rey upgrade Electric RC 2
The RC Car Slash to Tekno or Losi steering setup switch Electric RC 5
S losi 5ive t 2.0 start up Large Scale RC 0
Belgiumrcbasher Losi dbxl e 2.0 runtimes Large Scale RC 1
RatBuddie Looking to upgrade Losi Night crawler SE driveshafts RC Rock Crawlers 2
J Losi mini 8ight spur an pinon Buggy and Truggy 0
Alex.M Can someone with a losi scte do me a favour please? Electric RC 3
The RC Car $400 HPI Baja 5b and $190 Losi SCTE with 3800 castle motor Nitro RC 9
RcDCO2W Losi LST Aftershock 1st run onboard camera Electric RC 0
RcDCO2W Losi Aftershock petrol/Electric conversion. Electric RC 27
Alex.M May I introduce the Official Losi DB/TT Pro Thread! Electric RC 46
Oldblue Mini Losi Tire Size Help please Mini & Micro RC 8
J Looking for Losi part # LOSA3033 Short Course Trucks 1
J Losi dbxl 2.0 no brakes!! Help Large Scale RC 2
B Running too rich when hot - Losi 5T Large Scale RC 4
D3MON Losi LST #2 build Team Losi LST 46
P Will these LiPo batteries fit the Losi Rock Rey? Electric RC 6
JDHayes57 Losi SCT 3.0 body Short Course Trucks 2
B Losi Super Baja Rey Short Course Trucks 19
olds97_lss 2.4ghz losi micro LOSB9524 won't bind... Mini & Micro RC 2
A Bullet proofing a Losi Baja Rey? Electric RC 3
Matt43 Losi 22.2 running gear fit 22.3 chassis Electric RC 0
N Losi Nitro 8ight RTR buggy Nitro RC 3
T Getting Back into the game - Losi Aftershock Truck Nitro RC 9
E Need Losi Mach 427 parts and help please. Nitro RC 8
Y Losi baja rey play in center driveshaft? Scale RC 4
T Losi 22s SCT or Associated SC10? Short Course Trucks 10
Wheeliefast024 Losi 22 5.0 d/c engine Electric RC 0
