Okay, here's the damage from yesterdays racing, not bashing!
15° toe-in on the left rear LOL, hard crash indeed
look at that bend screw if you look closely and how the whole arm is moved and bend forward
and look at that bend metal pin retainer..
bend screw fiddlesticked up the rear gear housing completely
....on both sides....
And these are the issues I just discovered today:
- bent left front drive shaft
- loose pinion gear
- shot front diff case too, at the top: one screw was lost because the entire thread has gone and the other one is just sitting there
Its the connection point between the top of the front diff housing and the top brace....so now its lost a strong mounting point there.
- a mounting hole of the ESC got a crack - this bothers me the most because you can't fix this completely without swapping out a whole new ESC
But I will use the magic Sugru again like I did to hold my Traxxas receiver box in place, wich held up perfectly
Gonna use it to fill up the gap between the ESC and the chassis and I will use it as reinforcement around the cracked mounting point so it doesn't crack any further.
Maybe its me, but the plastics aren't worth poop, or plastics in general.
But than again, the difficulty of the track and me not holding back certainly have something to do with it...
I think chassis slap is the main responsible for the cracked ESC mount, all others is just due to hard crashes
There were 2 other guys and they also were send back with rc parts bills
I have already ordered the diff housings, a kit of 3 (fr, center, r) for only 17 euro or something.
A pair fr & r metal pin retainers, than I'll have a spare pair for the front, those come in at 12 euro's
And some screws, only the shaftdrive I still have to order, but they only come in pair, and are 40 euro's
I am almost certain the diff cases will get ripped again and than I will order these nice looking CNC Alu ones from Vitavon (only front and rear)
INDESTRUCTIBLE!
Just a general question, is it normal for a pinion to come loose even after you applied loctite?
I assume the heat has made the loctite go soft after a couple of runs in this heat.
So thats something you gotta inspect from time to time than?
