Daniel C
RCTalk Champion
- Oregon
- Racing
- Crawling
- Scale Builder
Damn, that is one crazy crawler. I like that you got shocks on and massive tires. The LEDs are pretty cool as well. A hiccup I might have is trying to build a water tight hull especially since you got a servo arm sticking out and it needs room to move. but I added some plastic and filled in gaps and holes in the stock servo pan. Now in the process of replacing most of the plastic with metal. I put wheels from a JJRC Q65 which are crossply style. it gives the truck a few MMs of increased height. I put upgraded lifting lugs on the front and an extra leaves in the rear. All around its still leaf strung But its better than nothing. View attachment 127854
The light bar is great. Really bright and works on a wide range of volts. I like that because I have to put a power regulator in most of the time to bring the power down to usually 3 volts for alot if lights I use. The other lights come from the light bar shown below but I removed the lights and installed them separately then used the round metal bar as a rear bumper. The shocks is a wpl upgrade in the rear with better shocks installed and the front is from a wpl Toyota truck. It works really good and has plenty of flex for it's size. Have you got to drive yours yet? If so how does it do. It looks like it has plenty of height.
