kalib
What up guys I seem to be having issues with my MM system. I'm running the 2200kv system in a buggy on 4s. Problem is that the after about ten minutes the motor appears to be "sticking" that's the best way I can describe it. If I push the car with my hand it rolls fine so I assume that all the drive train and diffs are good. If I pick the car off the ground and hit the throttle it spins fine. only when I put it on the ground and try to accelerate does it seem to stick. It just shudders and makes a weird noise but doesn't move. I check the motor and it was kinda hot so I'm letting it cool down. Has this ever happened to anyone and can some body tell me whats going on. BTW I'm running a 20t pinion. Thanks
