- Thread starter
- #141
Well the esc mount isn’t going as planned… to the scrap pile I go
what happened with it?Well the esc mount isn’t going as planned… to the scrap pile I go![]()
Here's what I would do man. Trace that cage onto a piece of aluminum, but make sure you leave material for the 3 countersunk holes. The gray piece below would be 1/4" or so aluminum plate.
Oh, are they outside the cage footprint? If so, that makes things much easier. You're not planning on using that adapter plate that came with the brace are you? I see it hiding under the cage there.Version 1 in progresswith the way the cage mount is I don’t think I need to counter sink them quite yet….yet
No not using that plate. The brace that it will bolt too has two threaded holes already and they will be under the cage. There will be room for regular screws and not flat heads. At least that’s the plan right nowOh, are they outside the cage footprint? If so, that makes things much easier. You're not planning on using that adapter plate that came with the brace are you? I see it hiding under the cage there.
thats sexy
Doesn’t look bad for some dremel fab! Wouldn’t be able to see it with the body on anyway lolIt does need some clean up still, and I will need to counter sink the front bolt at least (probably just do em both while I’m at it)
View attachment 201084View attachment 201085
It’s not quite squared in there, but meh
I’m probably gonna re drill the plate to brace holes now looking at it in the picture![]()
Thanks man!Doesn’t look bad for some dremel fab! Wouldn’t be able to see it with the body on anyway lol
A benchtop belt sander would come in handy here. But that looks great! Nice work man.
Hey, it's symmetrical. Just flip ot over and redrillThanks man! I’m going to clean up the edges some more and redrill that back hole. My dumbass had it marked right, then I drill the two side holes and tapped them. Then I sprayed the cutting oil off and there went my other two hole marks
I’m gonna get them bodies cut eventually too![]()
Straight lines. Don't do swirls as they will be much harder to get out in the next step. And it looks like you need a harder surface below your sandpaper (rolled over edges). Got a piece of MDF or similar to put under your sandpaper?It’s getting there @WickedFog
Still trying to get the scratches out…
Drilled through the cage and tapped the plate, the rear cover bolt will go all the way through into the plate
The swirls are cause for tried to polish it with a wheelStraight lines. Don't do swirls as they will be much harder to get out in the next step. And it looks like you need a harder surface below your sandpaper (rolled over edges). Got a piece of MDF or similar to put under your sandpaper?
It is getting there though![]()
