BenJammin
- Rhondda Cynon Taff, South Wales, UK
- Racing
Hi all, new member here.
I have a Kyosho Inferno MP9 TKI3 with the KE.21R engine. The buggy was purchased around 2017 and spent a few years sitting with no after run oil in it. When I dug it out a couple of years back, I had no issues getting it running - it basically fired straight up and has run well since. However, it makes an almost ear piercing metallic noise when you're near it. I've had the engine out and spun it over by hand to feel for bearing failure and it feels pretty smooth. Any ideas what could be causing the noise? I thought maybe it could be the pullstart shaft mechanism but I want to be sure before it destroys itself or something.
It also has a pretty burbly, rough sounding idle and spits lots of oil on tickover - pulls well at the top end and leaves a nice thin trail of smoke. Takes off well with no bogging, but smokes a lot on initial takeoff, and does bog a little if left to tickover for more than 10 seconds. Pinch test stalls at about 3-4 seconds (I'm aware the pinch test only gives a rough idea of the LSN tune). I'm thinking the LSN may be a little rich, but when I lean it out it starts to struggle on takeoff.
I can try to record a video of the noise but it's difficult to pick up on the phone due to the pitch of the noise.
Any advice is appreciated, thanks all.
