Not 200; 230.
It should be this before even starting. This way you can actually tune the thing. This is not a suggestion, it’s a requirement.
If it will not idle, your tune is not where it should be-unless you have OTHER problems. 90% of the time with a nitro engine that will not respond to tuning, either the operator is attempting to tune a motor that’s not at operating temperature (which is what you are doing
), or there is a MECHANICAL issue that you are attempting to tune around. IE-problems with your clutch, improper shimming, air leak, fuel flow issue, improper fuel, or plug, etc..
Number one issue is to stop trying to tune at 100F below operating temperature.
If it will not maintain temperature, wrap your cooling head in foil, or a paper towel. This will maintain temp until it is broken in.
-also, tank count has absolutely ZERO to do with wether your engine is broken in. Metal pinch is the hurdle here, and it varies wildly between different engines, fuels, break-in procedures, etc..
Those videos I linked you to cover literally EVERYTHING you need to learn, and apply. You need to pay attention if you hope to be successful. You cannot just pick & choose what you apply, and what you do not think is necessary-such as tuning without being at operating temperature.
