Kyosho FW06 Audi R8 2019
StephMir
Austin, Tx
Just bought this car. Still breaking it in and tuning it. I still want to tune it a bit more before I take it out onto a tar track. I replaced the rubber tires and went with slicks and it handles very well on the street. It does lower it more than stock tires by about a 1mm. It sits 5mm stock. Any tips and recommendations for this car? I'm running 20% Nitro fuel with stock glow plug. Only use it for street and some track runs. Had to cut holes in the body for air circulation.
Got the Foamies with black rims...it looks sweet! I also got the rubber slicks with chrome rims.
After cutting holes in body and put in slicks, I installed hot pink air filter and then re-tuned. its about 99% tuning, but it's HOT here in Texas! With this heat the engine will ALWAYS need to be tuned.
View attachment 119236View attachment 119237View attachment 119238View attachment 119239View attachment 119240
do you have a link to where got this car? or did you buy it a a local store?
Its a Kyosho branded. Not sure who makes it.
Uploaded some videos on YouTube.
Crash #1 Hit a reflector on the street...ugh! -
LOL...You run out of street real quick with these fast street rides!...:thumbs-up:
Mine makes my hands tremble every time I fire them up ,nice vids!:cool:
Wipe Out!
GoPro Mounted pt1:
GoPro Mounted pt2:
Body from a Kyosho FAB158 fits my 1/10 FW06 200mm. Painted metallic purple. Black Spoiler. I wish I had an actual Supra rear loop spoiler. The first pics still have the clear splash mask on. I can already tell its gonna be BOSS! Still need the stickers, ,mount the spoiler, the exhaust pipe hole and the mounting holes.
Put the body on the chassis. Had to raise the body supports to clear the fuel tank and the sides. Looks decent for my first paint job. Still hesitant about removing the clear splash mask. Still need to cut a hole for the Engine Heatsink ,the Gas Tank access and mount the rear spoiler.20191029_061651.jpg20191029_061703.jpg20191029_061711.jpg20191029_061724.jpg
Cut the holes for the exhaust, engine heatsink and pull start. Also, removed the inner window masks. Maybe when it gets a bit warmer and they finish paving my street I'll remove the outer splash mask and put all the stickers on and take some final pics before the shell gets all scratched and worn.20191029_184702.jpg20191029_184747.jpg20191029_184837.jpg
Ran the Kyosho down the street on a longer strip without many houses/driveways. Lots of wind, though. This is where the holes on your body/shell can make a difference. I have all the windows cut out and Its too much drag and causing a lot of oversteering. Also, I have the least sticky wheels on the Kyosho. I'm running the stock rubber wheels they aren't too bad, but with all the wind and weak traction the car seems unmanageable at higher speeds.
Finally finished the Supra Body. I really like the way the Metallic Purple came out.
Hey @StepMir, seen your videos on YouTube before I bought my first fw06 about a month ago. Wish I had seen this post before I ordered the supra body. It wasn't until after we painted it and I went to test fit that I found out it's truly made for the fazer and the body doesn't actually clear the gas cap. This being my first painted body, and aswell as it turned out. I really hate to chop a big hole in the window. I also wished the kit came with a loop spoiler. I ordered an aftermarket drift wing and am hoping It will fit the kit.
That paint looks sweet. My next paint job will be using something similar. make sure you put a lot of coats underneath for wear and scratching.
Yeah, unfortunately with all Nitro RCs, you have to do some cutting of the body. Either pull start, fuel tank access, engine heatsink or in my case, all of the above. As of today, 04/17/2020, I still haven't run my Supra body. I will run it to test the heat temperatures. I still may need some more holes in the body for air circulation, but I'll check the temps when its hotter outside.
Construction in the neighborhood has put a lot of rocks and dried mud so there is a lot of crap on the roads. Have to take my blower out there and clean up my street before I run the Kyosho FW06.
Kyosho FW06. Evening run. Moved the GoPro camera mount to the center. Steering is much more stable. Lowered the audio on the video. Also, lowered the video quality when uploaded. I will encode better quality in the future, since YouTube is allowing higher quality videos.
