A professional machine with a heated enclosure would have better layer adhesion even with an FDM process.
That is true. A heated enclosure is the way to go on any 3d printing. I'd love to get one for my main printer, but with a 500mm x 500mm x 500mm build volume, I need a heated closet lol.A professional machine with a heated enclosure would have better layer adhesion even with an FDM process.
Screwing parallel to the layers is always a bit risky. Especially on thinner parts.
The resin trick is really awesome. I have been using it for awhile now. I wish I had found it sooner. Oh the headaches it would have saved me trying to print tiny parts, yet keep them strong.
I haven't tried Elegoo, but I have been considering one of their resin printers. I just hate the mess of resin printing.I used this stuff - https://www.elegoo.com/products/elegoo-plant-based-rapid-resin?variant=39469352452144 but in clear, after doing some research. Stuff is literally made from soybeans!
I was printing fishing lures, and standard resins were just too brittle, and some people recommended this because it's far more pliable. Been using it for a few years now, and it's non-irritant for the most part, doesn't stink up the place either. And yes, the detail levels are vastly better, that was really important for my lures.
Holy cow man. Wow. What's the name of your RC company? Because you're at that level.
Very impressive and informative, I am changing my Nitro rustler to a 2 speed gearing and this post is hugely appreciatedThis is getting very close. Engine mount is finished, and I scored an alloy spur guard/brace. Just a couple of items to finish/cleanup, and need a warmer day to do a little testing. Yesterday woulda been perfect, but ah well. It was 70. Today it's 40, lol.
The brace works just about perfect, and I had some other piece (the little red thing at the end) from something I don't even know what, that allowed me to mount it to the chassis plate. There is even already a hole there (though it needs a slight tweak to line up perfectly).
I also scored some orange arm hinge mounts to replace the blue ones that didn't match the rest of the chassis. Those I had to grind down a bit because the transmission wasn't fitting with them. Note, steel spur gear too. No slipper either.
I will test pretty thoroughly with the OS .21 tm first. I'm really curious as to how much time will come off my ET's. My best time with the previous single speed Slash trans was 2.7s, which isn't all that fast (2 years ago that was considered fast though). Now guys are all 2-2.5s with SC chassis cars, and some are sub 2s. I'd be pretty happy with something in the low 2s range with this mill.
Then I will beef up the transmission, replacing all of the internals with steel gears, and better bearings. Because, you know, the next step is slapping a big block in this thing. The BB mount has the same bolt pattern in the base as the SB mount, so my existing CF mount plate will work just fine.
I will start with the KE25 and see how that performs. They aren't really the best, and I can't find specs on it but I don't think it's got a lot of top end. I just want to see how it launches, etc, and if things hold up with that somewhat tame BB mill. Then I will put in the Final Destination engine, the O.S .28 p8 which does have decent top end at 36k, and I'll also change the 54t spur to a 53t.
The SH is a 4+ hp monster, I have one in my Dragonoid, and it's a drivetrain wrecker in that rig, but this is going to be a pretty bulletproof drivetrain before I put that thing in. I am still searching daily for an alloy gear case, but no luck yet. Probably will have to wind up buying some Jato roller to get one, lol. Anyway, with that much power, the power to weight ratio for this car will be insane - comparable, or exceeding that of BoLink/RJ Speed pan drag cars. Those nitro cars run times as low as 1.6s, I've seen the slips. Currently the fastest SC chassis car time recorded is 1.78s, set very recently by Frank Uldrick (I think he works for a chassis builder). I'm not sure what motor combo he was running, might have been 4s or 6s, not sure, could have even been 3s to keep it NPRC legal, but that seems a little unlikely. Either way, I am gunning to break that record. With nitro. The power/weight numbers will be there, but can I get it to the pavement? That's going to be the real test. I had some traction issues with the OS .21 tm when I initially built this thing and had the short gears in with no top end speed, and now with the 2 speed it'll be even shorter and torquier on launch. The car also weighed 6.6 lbs then (with body), but is only a little over 5 now. I might have to re-add some weight, and find the magic combo.
Now just have to wait for the weather to be warm enough to run.
Let me know if this goes in to production. I want one![]()
