- somewhere on earth.
- Racing
- Crawling
That side exhaust is sick!!!Got some testing in on Saturday, as it was 45-47 degrees. No sun though, so still a bit dodgey. Packed the truck up and headed to my test spot, one last test with the ceramic bearings in.
Used the black body out of thinking I don't want to demolish one of my good green ones. I knew that this wasn't the best idea, but we are about to get doused with Winter here real soon apparently, so figured one last try to see what it can do and get some video. Conditions last time were about the same, and I had some traction issues, so my hopes weren't real high.
Figured I'd take a pic in case I wrecked it.
The car is a pretty far cry from the original, 2019 version! (bottom car was 6.7 lbs, with a small block and plastic gears vs 5.9 for the big block, steel geared car on top that has twice the HP!)
No wrecks, this was after two passes, car intact!
So, two hits, and they were both full passes, though I did have to get out of it at about 110-120 feet and coast to the 132 mark, but still going by the video time, these were right at about 2.0 seconds. The car started pulling right, which was probably due to losing traction when the car hits the peak power band. Doesn't help that it's riding the bar pretty much the whole run too (I do have the bar set really low, so the front wheels aren't too far up, but still had no steering). Thinking I should have used the green body because the wing on that body has way more downforce. Might have at least stayed planted.
Mo powa!I put the engine back together over the weekend and fired it up in my garage. Wanted to test out the big nitrous bottle. (pic from another post here)
It's double the size of the little one, which definitely worked but after seeing how much that .12 jumped in power with the little one, I figured the .30 needed a larger shot. I did a few tests to see how the engine reacted with it just sitting there idling. With the little bottle, the RPMS would just jump up. Testing with the big one, it's hard to explain, but the RPMS do surge, but it's a different sound altogether, kind of what I hear with the .12 and the small bottle. So, I think I was on to something.
I put the body on and charged the nitrous up to 70 PSI for a little test in front of the house. It was only 45 deg and the wind was picking up and temps dropping, so I didn't figure driving out to my usual spot would be a good idea since it's usually much windier there. Did a quick launch test, hitting nitrous at 10 ft. Good freaking lord Maybe one day I put these things on a dyno to find out just how much more power it's throwing down, but I can say, it's definitely a LOT.
I don't have video, but we have warm temps on the way, I should have something this week.
