jon2 said:For the Shocks I used Unlimited Engineering shocks with 35 wt Shock oil all around and Kyosho/ Ofna White stiff springs.
I did not know there was foam in the resevoir.Hmm Learned something new today
I took massive jumps with My MGT but on that one since it is a bigger rig I used all 8. No problem.
The Tmaxx only 4 and had no issues with dampenin. Just make sure you uncompress the spring and elevate your ride so the shocks get a break when not in use.
olds97_lss said:The shocks work fine on the savage. It still has pretty much the same travel as the stock long shocks, just shorter, beefier and better!
It will still bottom out and if you have all black springs, it will stand tall at full arm extension with 4 shocks.
The Nova towers are made of 7075 aluminum I think... Can't remember.
You can buy a UE shock/Nova kit here: http://www.hobbyshopnj.com/Savage21/
That's where I bought my shocks, but my arms, I got from www.newera.com
Like I said though, you don't get much tunability with the NewEra arms... as you can see in my pics, you have 3 holes to choose from and they really only work well in the furthest out hole IMHO.
