hpibullet
Hello i recently bought a hpi bullet mt 3.0. First off i already had to send the engine back after i broke in the engine, because the pressure pin off the connecting rod was not pressing hard enough against the starter plate hole it needs to stay in. so basically i would pull the pull start and it was not conected to the crankshaft. so i was happy to get a brand new engine last week from hpi. now here is what i need help with. the engine is running great BUT the instruction manual tells me not to turn the high speed needle more than 3/4 of a turn. The manual states, find a needle setting between 1/4 and 3/4 a turn clock wise (leaner) that gives good throttle response and top speed. My problem is at the max: 3/4 of a turn my truck is very sulgish and has a horrible top speed. my low speed needle is fine i know that for a fact. with the high speed needle at 3/4 not only is it slow but the temp is at 140F witch is too cool. The manual says it should run at 230F. I have the needle at 1/2 turns from flush and get great proformance great top speed and the temp is at 180F with no body on and with the body on i get 210F so not bad at all considering they say 230F is normal. so my question is why does the manual say do not exceed 3/4 of a turn meanwhile i am at 1/2 turns in and it runs a little richer that they say is top proformance. i am scared of being over the recommended max setting leaner on the high speed needle. is it a mistake in my manual or am i wrong. thank you for your help and tell me what you think.
