hotbodies wont start
Status
Not open for further replies.
jack
Gone - bye bye.
warrington
my hot bodies lightning starts then wen i finally get it warm i take it on the grass and it revs but dosnt go any where is it my diffs which might of given up or is it part of my setting on the carbaretor.
cheers jack / any ansers ?
The drive gear attached to clutch might not be contacting the gear(s) in the tranny, try loosening the engine and properly meshing the gears back together, and make sure you tighten the engine real good when you're done.
I know this from experience. My engine would've come off if it hadn't been attached to the exhaust and fuel linkages.
Check your slipper. Sounds like the nut on your spur gear is to tight. If your diffs were bad, they usually will make noise. Try loosening the nut on your spur a a little bit.
Thread starter no longer a member.
Thread closed.
Status
