Hi all,
I have a Hobao hyper 7 tq sport .21 that has been in storage for 5 yrs+. But worked fine before going in.
I thought I'd bring it back out, before starting changed the glow plug (os 8)
Fresh fuel and also fitted an electric starter
Tried to turn over by hand and think it was possibly seized. Continued to turn it over on the flywheel by hand and it freed off.
Went to start it - no good, not even a kick
Carb Settings were how they were left when it last run. Disassembled the carb, cleaned everything and reassembled
So, thought back to basics, reset the carb to factory (both ends flush, idle at 1mm gap and main needle 3 turns out) still no start
To get it to run, I have to have the STNV OUT approx 2mm from flush, it runs very rich and there is plenty of unburnt fuel coming from the exhaust. When in this state it starts and idles no problem. After it gets warm, I trying to throttle it obviously bogs and cuts out. So I lean off the STNV and it drives OK and will continue to start afterwords. BUT as soon as it cools down, it then won't start with the STNV left in it's lean position, I have to wind it back out to rich?
Also have a split/missing throttle boot but believe this just to be a dust cover?
So, 2 trains of thought, something of concern inside the motor after it potentially seized or an air leak/carb issue?
Any thoughts or theory's would be appreciated
Thanks
James
Thanks
James
