Wait a min ignore this last message I think something is twigging I just need to digest one of the posts correctly
I think the key is that "ma" and "mah" are measuring different things. The first is a flow rate, and the other is a sum over time.
As for the 14.8 / 16.8v thing - that's the "nominal" versus maximum voltage of the battery. It's why we often refer to systems as 2S or 3S (or more), because it gets confusing fast, especially at higher voltages, what someone might be referring to. Nominal means its the average voltage from full to empty; a lithium battery at 100% charge has a higher voltage than one at 30%.
A lithium battery has a nominal voltage of 3.7 volts, which is where 14.8 comes from (4x3.7), but a maximum voltage of 4.2v, which is where you get 16.8 from.
You'll set a low-voltage cutoff in your ESC of something like 3.1 volts per cell, which is 12.4V. Seeing the charger go from 12.4V to 16.8V just means it's charging it back up to full.
Any one find a decent easy diagram of how amps flow and volts ?
I think what you're missing is
ohm's law
Let's use light-bulbs instead of motors for a second, and I need to introduce a third value, "resistance"
Voltage is abbreviated "V" (volts, easy)
Current is "I" (from "intensity")
Ohms are "R" (resistance)
Power is "W" (watts) - this is the true measure of energy flow; volts
times amps
Imagine we're using a 6V battery, with 1000mah of capacity.
You hook up a lightbulb with 6 ohms of resistance.
Current = voltage divided by resistance ( I=V/R )
6 volts / 6 ohms = 1 amp.
Power = volts times amps (W = V*A)
6 volts * 1 amp = 6 watts.
The lightbulb will glow with 6 watts of power, and the battery will last 1 hour.
You recharge the battery, and hook up 2 lightbulbs in
parallel. They both have 6 volts across them, so each draws 1 amp, for a total draw of 2 amps.
The battery is now supplying 12 watts of power, and only lasts half an hour. Each bulb glows as brightly as the single one did before.
You get a second battery and connect it in parallel to the first. Their voltage is still 6V. The brightness of the bulbs does not change. Now their combined capacity is 2000mah, and they can power the 2 bulbs for a whole hour. You remove one of the bulbs, and now they can power a single bulb for 2 hours.
You replace the lightbulb with a more powerful one - counter-intuitively, it has a lower resistance, 3 ohms. You hook it up to your 2 batteries in parallel. and it draws 2 amps of current (6 volts / 3 ohms = 2 amps) - it's drawing 12 watts of power, (6 volts times 2 amps), glowing twice as brightly as the original bulb. It'll drain the 2 batteries together in 1 hour, or a single battery in half an hour.
It's fun stuff, and once you get the hang of it you'll never forget, it opens up tons of modding options to have a firm grasp of the theory.
