I have a redcat shredder running 6s with leopard motor etc., I have the 49 tooth steel gear with a 17 tooth pinion. I have been stripping the steel 49 gear because it's like if I have the pinion gear meshed-in close with the gear teeth then it's like it gets stuck and the wheels won't move because it's too close meshed. If I pull the pinion out a bit then it doesn't grab enough and then starts stripping the gear. I saw I needed a 'mod1' pinion which it is so I don't know what to do to get the teeth on both parts meshed good and tight and be able to move the car like it should.
