Redcat Vigilante 8S
Bobbyredneck
Is there a 24mm 23mm hex adaptor i can get for the Redcat Vigilante? I can't find one anywhere, I really want to buy the Maverick Blackout MT's but they're on 23mm hex.
Help! 🙄
Welcome to RCT
I don't think you're going to find an adapter for a 1mm difference. If the wheels are 23mm and your hex is 24mm, then you either have to remove 0.5mm from each surface inside the wheel hex recess (easy if they are plastic) or replace the hex on the Redcat with a smaller 23mm.
I don't know of any sources for a 23mm wheel-hex.
Welcome to RCT
I don't think you're going to find an adapter for a 1mm difference. You'll likely have to remove the 23mm wheel hex and install 24mm.
Any chance the Arrma 24mm hex will fit the Redcat? If so, Jennys RC is a good source for new take-off parts at good prices.
https://jennysrc.com/search?type=product&q=24mm
Yea I dont mind using a 23mm wheel hex, so where would I find one of those to fit the Vigilante? I dont necessarily need to use an adaptor.
Thanks.
