one of my servos recently took a dump do I want to replace them with savox servos, what do you suggest?
I would like to do 2 servos and what parts do I need to make them work?I would go with a single servo set up such as this:
http://www.rpphobby.com/product_p/savsa1283sg.htm
I should also add that you may need an external BEC (Battery Eliminator Circuit) because all of the Savox I've used can cause brownouts and loss of control if your ESC doesn't put out enough current.
It's a full size revoIt's better to go with 1 servo as it's easier to get it set up. 2 servo set ups tend to be a bit more work and expense, IMO. If the 2 servos aren't centered properly, they tend to fight each other which uses extra power and causes premature servo wear. I used a single HiTec HS-5655TG in my Revo 3.3 for a while, before going back to stock servos when I thought about selling it.
Is this the full sized eRevo or the 1/16th Version (mERV)? I have both the Revo 3.3 (which is the same size as the 1/10 eRevo) and a mERV VXL. Even with bigger tires and beadlocks on mERV, it gets by on the single stock servo even being punished with the Brushless/3s LiPo combo.
Here's a pic of the little monster:
Thanks!Here is an exploded view from Traxxas. It shows all of the parts for the front end including the dual steering servos:
https://traxxas.com/explodedviews/E-Revo-56036-4-Front-Assembly-Exploded-View
Here's a good servo that should fit and work for a dual servo set up and the Y-adapter:
http://www.rpphobby.com/product_p/savsw0231mg.htm
http://www.rpphobby.com/product_p/gea1305.htm
Just remember that Savox servos in general tend to be current hogs and can cause brownouts if your Battery Eliminator Circuit (BEC) isn't up to it but that is fixed relatively easily.I went with a single savox sb-2270sg.
I'm aware, thanks!
The savox sb-2270sg? It has nearly 300oz of torque even not on 7.2V. If it's not turning your wheels... you have severe binding issues. Did you get the HD servo saver spring as well? I run a 172oz servo on mine and if I hold the wheels stationary, it will overpower the HD saver spring. I think the savox 0231 in my other revo will do the same. Neither of which have nearly the torque the s2270sg has.I got it installed and it won't turn the wheels!
That will help, but on carpet, my servos still overpower the spring. The stock spring is pretty weak. The HD spring makes it more responsive, but anything over 200oz is kind of a waste on it as the spring gives way pretty easily. The good news is, you more than likely won't damage your servo, ever. At least not due to smacking into to something.
Yeah
Not really. I put mine near the receiver. Less wire dangled across the truck that way.
Ok
Here is what's happening!
