Suburban_Hooligan
Rig of the Month Winner
RC Showcase: 22
just going to leave a little motivation
2 coats of liquid mask on. I was trying to get this caught up to the SCT bodies, but I went ahead and put another coat on them too, so they now have 4 coats
@Littlemotor - I decided to grow a pair* and forego the supplied window masks. I am going to be cursing your name while I cut all these windows out, as some areas will be a real pain to get to.
* I actually didn't grow a pair. I simply got too anxious and started liquid masking the the two SCT before realizing I forgot the window masks. Then I did the same damn thing with the bug, which will ne the worst windows to cut out![]()
Oh snap. Did I miss something?Takes patience is all man! You got this!!! This is what separates the men from cc1999!!![]()
/me cowers away in fearNo pressure.![]()
Thanks man. Cutting the tearoffs and motor components took longer than expected, but everything is ready for paint now. Just gotta get up the nerve to start spraying.I know this will be good, your paintwork is always killer.![]()
I haven't seen any paint work out if you in awhile either
I haven't seen any paint work out if you in awhile either![]()
It's great. I am much better at cutting it out than I am drawing the designs. The trick is to use a #16 stencil blade instead of the normal xacto blade. And it's better to have too many coats than not enough. I went 5, but some areas were just a little thin and wanted to tear while peeling. So 5 coats minumum for me. I'll likely go 6 from now on. It would be much better if I could spray it.How you liking the liquid masking so far?
Glad to hear the #16’s are working out for ya over there homie.It's great. I am much better at cutting it out than I am drawing the designs. The trick is to use a #16 stencil blade instead of the normal xacto blade. And it's better to have too many coats than not enough. I went 5, but some areas were just a little thin and wanted to tear while peeling. So 5 coats minumum for me. I'll likely go 6 from now on. It would be much better if I could spray it.
