BOUTCH
Sorry bro, but this hobby INCLUDES wrenchin. Youll get to like it beleive me and dont worrie about those chores
uke:
Stay with it. We'll get you through. You'll be chasing Kangaroos in no time.
Disassemble the engine completely (head, sleeve, piston, backplate, even the carb) so that it is just the crankcase and bearings. This includes any o-rings that are down in the intake, and clean out ALL fuel/oil.
Now, get a good heat gun, and with the gun on high, hold the engine in a pair of LARGE pliers with gloves, and get the block good and hot. Hold the heat gun at the back-plate area of the engine facing inwards, count to ten, then rap the engine on a wooden surface that you don't care about, backplate opening down. The bearing should literally fall right out. Repeat process to install new bearing, using the crankshaft to pull the bearing into place.
