Current TRX4 build
Arbgarry
RCTalk Racer
Scotland
  1. Crawling
  2. Scale Builder
It's been a while since I was on here, think the last pictures I put up were a Cherokee hardbody, since then it's been a Cherokee half cab and a Toyota Surf (4Runner)
It's now back with a single cab Power Wagon body, Hobbywing Quicrun 2in1 1800kv motor, 8 channel R9B transmitter, hacked FlySky GT3B, also running 8 channels, GMade steel beadlocks with Hyrax tires, front 15 kg servo winch, rear servo winch is awaiting delivery, headlights and tail lights, skid plates and a shortened chassis.
I'm waiting on a cantilever suspension kit coming, so I can make a custom rear ALU bed or tub.
I hacked the FlySky GT3b last week, I also put a better voltage regulator in, the batteries last a good while now.
Looks awesome man. Love that paint job! Hope you get to feeling better.
Do you like the GT3b hacked? I modded mine once and loaded after market firmware years ago but I thought it made the radio to cumbersome to use easily.
Yea i like it not sure what firmware you had, its currently 0.6.0.1.s19, i have it set up in a way that works for me, ch3 single button is the lights , using ch3, ch3 trim 3 position switch is the front servo winch, using ch4, ch5 is the D/R trim 3 position switch 9 set up for a rear winch, so lights, front and rear winches are all easy to work, while steering and throttle, its only my thumb that needs to move, the back button is set to ch6, single press will do crab, left or right if i go rear steer, the steering trim and throttle trim are unsigned just now, but i still have 2 spare channels in the RX.
Looks good, Mate!
Wishing you a full recovery soon!
Thanks , gona be a long haul, short story, got a booster vaccine in Dec last year, not been good since, I've got Neurological damage as a direct result of the jag, severe intermittent memory loss, adrenaline spikes, low iron and a load more issues, the UK is still at a point where the vaccines are praised, so its hard to get the Doctors to talk about what's happening to me.
Well, hope you get everything sorted, sounds like they have made a mess of things.
They messed me up big time, iron level is ment to be 60 and above, 3 of my 4 iron levels were single digits, they thought this was causing the memory loss, but when the iron was back to normal, no other changes happened, i got a Alzheimer's test, and failed, all treatment fails, and I'm now awaiting on a Neurological specialist to take a sample of my spinal fluid, it's slowly getting worse, I'm forgetting simple things like what toothbrush is mine, sometimes i stutter when talking, because my brain wont work properly.
Working on the rc crawler is my go too, its takes my mind of things for a while, its been fully stripped so many times now, just to give me something to do.
Very nice...
TRX-4 on my list for maybe a snowblower project.
Keep going.
PL
Having a fair share of health problems myself I can imagine how horrible thats got to be. My issues arent even that terrible and half the time it makes me miserable. Much like you I find a lot of comfort in my hobbies. I pray that they find a way to make things better for ya and soon! :)
Hope you have a quick recovery.
Time will tell for me, the Doctors can't diagnose me, but the Neurological specialist can, but the fact i need to see them, makes it the worse case scenario, for now they think i have a chemical imbalance in my spinal fluid (brain fluid) They dont know what cause it, so that means they dont know how to fix it, I've been told i may just have to live with the memory loss, and that i wont ever work again, I'm only 43, i should have years ahead of me, but depending on how bad i get, i may get to a point i dont know who i am, and need put in a care home, without being morbid, id sort the problem myself before it gets that bad.
I feel it. I'm only 48 myself and I've already had a heart attack and a whole slew of other issues that I wont go in to detail on. I have some some good days and other days......
Addict Rc
Replies
25
Addict Rc
Addict Rc
cranemodel1015
Replies
9
2K
cranemodel1015
cranemodel1015
FREEDOM83
Replies
9
3K
FREEDOM83
FREEDOM83
D
Replies
1K
Dark_RC_Corpses
D
