I'm trying to fit a .26 engine on a buggy that was designed for a .21 and it appears I'm gonna have to do some modding to get it to fit. (Yes I know its like putting a corvette engine in Honda civic but I have a buggy with no engine and an extra engine laying around so it seemed like a fun thing to do even though I know it will probably spin the tires right off of it lol) So in order to get this engine to fit I'm either going to have to remove one brake pad and disk from the rear side of the center diff, or cut a small rectangular hole in the chassis. The hole is because when the .26 engine is mounted on the engine blocks the crankcase is fine but the backplate sticks down about a 1/4 inch lower than the engine mounts. So the hole would basically be for the bottom of the back plate to sit in and lower the engine down. I currently have spacers mounted on top of the engine mounts to raise the engine up high enough so the back plate doesn't touch the chassis. I thought that would work until I tried to put it on there and now the flywheel is hitting the rear brake pad.
So the question becomes would you mod it to just run one break pad in the rear or would you cut a small rectangular whole in the chassis for the bottom of the backplate to sit in? If you would cut a hole in the chassis is a dremel capable of cutting 1/8 inch aluminum? If so what kind of bit would I need to buy for my dremel to do that?
P.S. I dont want to have to bump start it so changing the backplate is out.
