- The Netherlands
- Flying
- Boating
Started out this way (in 9 days, on 27 may, I'll have owned this RC for one year)
then I added a different engine and pipe because I thought this engine was hopeless (in reality i recently found out that even though the lack of compression and large play between the piston rod and crankshaft it does work)
then I kinda replaced This inside of the case, including the gears & the shaft they're on, into the stock transmission case of the car
In order to have more space and play and not create friction, I slightly "dremeled" a bit out of the spring mechanism
this should not influence it's working as I only "touched" the outside, not the mechanism itself. Then, there still was a bit of friction with the bigger first gear so I dremeled the chassis a tiny bit
now it does fit nicely.and I don't know whether I took pictures, but I also had to dremel out a bit of the end of the shaft:
I'm unsure of what side I did it tho. I think the front. Here I put it together:
Now this is the final result:
