WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
Yes. The smart chargers and batteries are meant to make it easy for people to get into the hobby. But they are just a bandaid trying to fix a bigger problem. People just don't take the time to learn how to care for LiPo's, and burn their house down. And having a smart charger doesn't fix that.Ohh...that's a smart battery. So there is a normal one too..
One reason is they don't allow you to read the internal resistance of your battery cells, so the only way to know when your LiPo is going bad is when they puff, or start to perform horribly. And by that point, you are already way past the point of risking a fire while charging your batteries. The smart chargers remove all the necessary info your charger will tell you about your battery condition. With a regular LiPo charger that can read internal resistance, you will know long before you reach that point that your battery needs to be disposed of.
If you're only going to buy one RC, and a couple batteries, sure, go ahead. But when you decide you are hooked on this hobby and want another RC to play with, there you are, stuck with a proprietary battery and charger, and your new RC might not even work with that technology unless you change the plug out. Traxxas batteries don't work in other branded RC's, the same way the Spektrum smart battery crap doesn't work in Traxxas RC's. Stay away from smart batteries.
You're MUCH better off buying a decent charger NOW, rather than later. That way you are not at all limited to what brand batteries you buy, and can get much cheaper, and better performing batteries.
