- Bozeangeles, Montucky
- Crawling
Mostly build pics with some parts listed kinda randomly...
Start at the start
Went straight to brass for knuckles and portal covers, got a Holmes stubby 2500kv with a 13t pinion. Should be geared low enough with the 39t spur to limit chassis loading and keep fairly cool. I can always pinion up later. Still have to put in the mamba micro and get the servo mounted. Then I'll build the shocks (likely go with heavier fluid in those) get the links on it and put the fancy TGH wheels & trencher crawlers on, and figger a paint scheme fitting a trash panda...
And since I just found the overdrive gears for the front end, I'll have to take it apart again, d'oh!
Start at the start
